So I've got a lone hard drive sitting on top of my power supply thats running quite hot so I decided to get a hard drive cooler for it. I found a few but I'm going to decided which one to get depending on what size  quietest fan I can find.
120mm: http://www.newegg.com/Product/Product.aspx?Item=N82E16835119010
60mm: http://www.newegg.com/Product/Product.aspx?Item=N82E16835119063
80mm: http://www.newegg.com/Product/Product.aspx?Item=N82E16835233080
So whats the quietest 120, 60, or 80mm fan out there? I'm not looking for a really high performance one since its just going to be cooling 1 hard drive
https://linustechtips.com/topic/20794-quietest-fan/
Correct. If you care about looks, you'll probably find Noctua fans are hideous. If that's the case, go with Corsair's Quiet Edition fans.
https://linustechtips.com/topic/20794-quietest-fan/#findComment-248811
The quietest fan is the fan that isn't spinning :P
Just kidding, it's really not a smart idea to keep a hard drive on top of your power supply. If anything, it would make more heat. Try placing the HDD elsewhere in your case (if you can) and see if it cools down a bit.
https://linustechtips.com/topic/20794-quietest-fan/#findComment-249150
You don't need to cool a hard drive. Just sayin.
My Best 2013 Bitfenix Prodigy Build  Case: Bitfenix Prodigy White | Motherboard: ASRock Z77E-ITX | CPU: Intel i7 3770k | CPU Cooler: H100i | GPU: GTX 690
Fan Controller: Bitfenix Recon | Ram: Patriot IEM 16GB @ 1600mhz | Primary Storage: 2 x Samsung 840 Pro 256GB | Backup Drives: 2 x Seagate Barracuda 2TB | PSU: Seasonic X850
https://linustechtips.com/topic/20794-quietest-fan/#findComment-249584
The one on the fx5800 ultra
Listen if you care.
https://linustechtips.com/topic/20794-quietest-fan/#findComment-251308
Corsair has some quiet fans, but if you have a case with no windows or you don't care about the looks of the fans, take a Noctua fan.
P.S. NOCTUA MAKE BETTER COLORED FANS PLEASE.
MSI MPower Big Bang | Intel 3570k
Samsung Pro 840 256GB | Asus R9 280x DirectCU II Top
Seasonic 750w Gold
https://linustechtips.com/topic/20794-quietest-fan/#findComment-251528
