Hey everyone,
First off, if you've helped with any of my problems previous thank you. Your Awesome.
My current problem is that I currently have my oc settings for my i5 3570k to run at 4.4ghz at 1.25 volts. It was doing perfectly fine, but right now my overclock settings are still saying they are set to where I want it, but the clock speed is at stock clock speeds.
Anyone willing to help with this?
I have:
i5 3570k
Asus P8Z77-Pro
Samsung 840 pro ssd 256gb
Sapphire HD 7950 vapor-x
That should be enough to get things started.
Thanks in advance.
Corsair Vengeance C70 * Asus P8Z77V-Pro * i5 3570k * Corsiar Vengeance 16gb 1866 * EVGA GTX 780 *
Samsung 840 pro 256gb * Corsiar AX860i
https://linustechtips.com/topic/20783-overclock-not-working-right/
What are you using to show clock speeds?
cpu-z, the ai tweaker from asus, and cpu real temp. the multiplier and everything is what I set it at, but the clock speed is at stock...
hmm record all your oc settings in your bios and do a hard reset of your bios (pop out the bios battery). once done turn off all the asus tuning stuff, turbos and if u see anything else that does anything with clock speed, then proceed to re apply your oc settings
(1) high frame rate (2) ultra graphics settings (3) cheap...>> choose only two<<...
if it's never been done then i'm probably tryna do it. (((((((Bass so low it HERTZ)))))))
Check with the bios to see if it is set at your clock speeds. Did you disable the power saving features?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
So I got it working right. But it included reloading the settings. Before windows was saying that I only had 1 core.
is LLC (load line calibration) turned on? if not turning it on
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
Also, some Realtemp disable turbo, making it go to stock while the app is running, go into your settings.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
