How to decrease RPM on my fans?
I just got new build. I have 2 fans on top(artic coolers),1 on front(artic cooler),and one that came with case,on the back. I also have Raijintek CPU cooler.
I want to decrease rpm of my fans,if that is possible. The only thing that is making noise in my case are them,and Since my room is cool enough,and I have good air flow in my case,I want to decrase them at least a little bit.
Is this possible?I installed fanspeed and openhardwaremonitor but it seems that the other one cant see fans,and I dont know how to set speed with fanspeed.
Can anybody please help me?
https://linustechtips.com/topic/207587-how-to-decrease-rpm-on-my-fans/
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
You can try checking the BIOS for any kind of fan control and set them to the "Silent" preset.
I am sorry but I would rather not messing with my bios because I really never like to mess with it. Also I just got build today and it was about 2500$ in my country so I dont want to do something lol
I will check this
If you have a spare 3/4 pin fan header (cpu) you can buy & connect a 12v to 5/7v adapter to reduce the rpm of the fans. If you're tight on budget then you can smash delete/f12 to go into your BIOS, then set them manually or according to pwn.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
I heard that people do it with speen fan or some other programs. Is this possible as well?
Check out your motherboards website and see if there is any software available, if not then you can always get other ones like speedfan.
Or you can just set up a curve in your BIOS. Sometimes there are presets like ''Silent'' and ''Performance'' etc. You can simply select these too.
SimRacer - Casual FSX Pilot!
Mobo: MSI B550 Tomahawk | CPU: Ryzen R5 3600 | GPU: Vega 64 Sapphire Nitro | RAM: 16GB Crucial Ballistix DDR4 3200Mhz | PSU: EVGA P2 1000W 80Plus Platinum | Storage: 256GB Samsung 840 Pro SSD - 1TB WD Black - 2TB Seagate HDD | Cooling: Dark Rock Pro 3, Noiseblocker eLoop Fans | Case: Phanteks Enthoo Luxe | Audio: Sennheiser HD598 - JBL LSR305s | Display: BenQ EX3501R, Asus VG278H
What motherboard do you currently have in your desktop? I believe you were referring to asus fan-expert software.
I have gigabyte z97 d3h
I'd either go into bios & turn them down manually or buy cheap fan voltages adapters.
yes speedfan might work, i use it but it's a real pain to setup
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
Use speedfan! It's actually not that difficult to set up ( I have my intake fans at 100% all the time and exhaust fans which are temperature controlled) So i have positive pressure while idle (= less dust) and negative pressure while under load (=better cooling)
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
This is a video to help you! You can go to Configure--> Fan control --> advance fan control --> add fan and let them scale with either your CPU tempt or your GPU tempt! :) hope this helped!
