Inverted ATX Case, Your thoughts?
Go to solution Solved by TheKDub,
The motherboard would just be upside down.
Hey so im thinking about upgrading my PC Case since I have a Cit Mars B and its incredibly loud if you leave the side fan on, so I was wondering if this was any good?
http://www.amazon.co.uk/AvP-Wolverine-Inverted-Blue-Tower/dp/B00940X4M8/ref=sr_1_14?ie=UTF8&qid=1409447800&sr=8-14&keywords=atx+case+blue
Only thing putting me off is it being inverted, would you simply just have to rotate the motherboard when you install it or would i need a brand new motherboard?
any help is appreciated!
Thanks!
My PC Specs:
Intel i7 4770k 3.2/3.9Ghz
AMD Radeon R9 270x GPU
8GB Crucial Ballistix RAM
Corsair Cx600
Seagate Baracuda 1TB
MSI Z87-G43 Gaming MOBO
Windows 7 Home Premium 64-Bit
TP-Link Wifi USB
Aula Keyboard and Mouse Set
Aula Mouse Mat
https://linustechtips.com/topic/207200-inverted-atx-case-your-thoughts/
Eh, I'd get a different case TBH. I think Silverstone has a case you can invert the layout with.
Im not looking for inverted in particular, I just want a Black case with blue LED's to go with my setup haha, and this one looked awesome, just wanted to see if it was gonna be any harder to build. Not built inverted way before
A little more expensive. http://www.amazon.co.uk/Corsair-Graphite-Compact-Windowed-Computer/dp/B00EWHOIDC/ref=sr_1_4?s=computers&ie=UTF8&qid=1409449698&sr=1-4&keywords=230t
