I had an xbox 360 and have been thinking of building a gaming pc rather than buying a ps4 or xb1 I have a budget of around 650-700 US$ I want to build a pc which can run any latest or upcoming titles such as assasins creed unity and bf hardline at some nice FPS can someone please recommend the parts for the build???
https://linustechtips.com/topic/206908-pc-build-help-required/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($99.99 @ Newegg)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($112.98 @ OutletPC)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($199.99 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case  ($49.99 @ Micro Center)
Total: $686.66
Generated by PCPartPicker 2014-08-30 11:25 EDT-0400
You will need to OC the FX-6300 to be able to keep it for future upgrades/current CPU demanding games.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2807382
@Archangel1994 he needs an OS though...
Maybe a downgrade to the 750/750Ti/285? They'll be able to perform admirably if he lowers the settings a bit...
OP
Do you need a Monitor, peripherals, OS, etc? If so what resolution do you want to run at, and do you have any preferences? If no what resolution does your monitor run at?
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2807410
His previous posts mentioned that he had 650-700 for hardware so I didn't include it on purpose.
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2807423
I have windows 7 64 bits
i don't necessarily want a 1080p resolution I have mouse and keyboard and I was thinking of connecting pc to my tv through hdmi
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2807482
@Anmol182
give me a minute to build the R9 290 Version
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($109.98 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)
Motherboard: Gigabyte GA-970A-D3P ATX AM3+/AM3 Motherboard  ($69.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($76.50 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ OutletPC)
Video Card: MSI GeForce GTX 770 4GB TWIN FROZR Video Card  ($369.99 @ Amazon)
Case: Rosewill R536-Red ATX Mid Tower Case w/500W Power Supply  ($56.00 @ Newegg)
Total: $761.43
Generated by PCPartPicker 2014-08-30 13:12 EDT-0400
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2807990
Fully AMD Build @Anmol182
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($364.99 @ Newegg)
Case: Raidmax ATX-298WBP ATX Mid Tower Case w/500W Power Supply  ($39.99 @ Newegg)
Total: $740.42
Generated by PCPartPicker 2014-08-30 13:20 EDT-0400
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2808025
@Anmol182give me a minute to build the R9 290 VersionPCPartPicker part list / Price breakdown by merchantCPU: AMD FX-6300 3.5GHz 6-Core Processor  ($109.98 @ OutletPC)CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)Motherboard: Gigabyte GA-970A-D3P ATX AM3+/AM3 Motherboard  ($69.99 @ Newegg)Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($76.50 @ Newegg)Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ OutletPC)Video Card: MSI GeForce GTX 770 4GB TWIN FROZR Video Card  ($369.99 @ Amazon)Case: Rosewill R536-Red ATX Mid Tower Case w/500W Power Supply  ($56.00 @ Newegg)Total: $761.43Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2014-08-30 13:12 EDT-0400
will the AMD FX-6300 3.5Ghz be able to handle the next gen games or do I need to spend mainly on mid end,high end GPU AND CPU to be able to play for about 2 years without upgrading it again
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2808785
With Archangel1994s build you should be fine for a while, though you probably won't be playing on high settings.
Still should be a good bump up from Console though :P
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2811377
will I be able to play a resolution that looks good 780p?without dropping the FPS below 50 with gigabyte radeon r9 280 3gb GPU or do I need a higher card like lolbry9 suggested with radeon r9 290 and geforce GTX 770 twin frozr
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2812643
The 280 should be good for most games at 1080p, though I'm not sure about the 50FPS on max. settings. Maybe if you went on Medium you would be fine
On 720p it should be able to play any game over 50fps.
lolbry9's build uses cheap cases+PSUs, which isn't usually recommended since a bad PSU could kill your entire system. - Archangel has a great build, go with that instead.
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2812868
thanks and can I connect it through hdmi and can I play ac unity which as people are saying is a more demanding game and can I choose bitfenix prodigy as the case
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2813188
well for unity i think the 280x will suit you better and makes it able to play newest titles on high to ultra
CPU: AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($84.74 @ Amazon)
Motherboard: ASRock FM2A88X Extreme4+ ATX FM2+ Motherboard  ($75.99 @ Amazon)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($72.00 @ Newegg)
Storage: A-Data Premier Pro SP900 128GB 2.5" Solid State Drive  ($69.99 @ Amazon)
Storage: Seagate Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($50.99 @ Amazon)
Video Card: VisionTek Radeon R9 280X 3GB Video Card  ($249.99 @ TigerDirect)
Case: BitFenix Comrade ATX Mid Tower Case  ($35.99 @ NCIX US)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($65.96 @ Amazon)
Total: $705.65
Generated by PCPartPicker 2014-08-31 03:29 EDT-0400
https://linustechtips.com/topic/206908-pc-build-help-required/#findComment-2813423
