Here's the thing...
When I turn on my PC it will turn on for 1-3 seconds then it will turn off... After 2-3 seconds it turns on by itself then do its own business... I've tried plugging in the psu many times but it's still the same issue. It doesn't turn off during the rest of the boot up but I'm concern if it will damage the components inside my rig.
Need help.
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/206732-boot-problems/
Here's the thing...
Need help.
is your cpu overclocked ?
https://linustechtips.com/topic/206732-boot-problems/#findComment-2806178
