Okay, So I just built a budget PC with some parts crappy, And some very nice.
I'm using an old PSU from 1 or 2 years ago (500w)
Plus only 2 pins on the heatsink mount are working and are pinned in.
So I'm just wondering whats the worst that can happen, Because I'm a little nervous to see if it turns on lol
Somebody reply with some tips, I'll post updates about the startup when somebody replies.
https://linustechtips.com/topic/206482-help/
Don't turn on your computer or else it will burn out your processor. Before taking any other steps get a WORKING heatsink for your processor, you can buy a nice one for around $15 USD online. And could you tell me what the brand/model of the power supply is?
My PC:
CPU: Xeon E3 1230 V3(Haswell) @ 3.7GHz Motherboard: AsRock B85M-ITX RAM: 8GB Corsair Vengeance LP Blue @ 1600MHz Storage: Intel 520 Series 120(Boot), Seagate Barracuda 500GB @ 7200RPM, Western Digital Caviar Green 1TB @ 5400RPM GPU: ZOTAC GTX 970 @ 1.4GHz Case: Node 304 Power Supply: CX430
https://linustechtips.com/topic/206482-help/#findComment-2802315
The heat sink works fine, Its just the pins that dont work, The pc is laying on its side.
And does it matter if theres a fan attached to the heat sink? Because the fans that are next to it is pretty close
https://linustechtips.com/topic/206482-help/#findComment-2802349
YES YES IT MATTERS. And the heatsink needs to have pressure onto the CPU so it can make sufficient contact. Did you apply thermal compound?
My PC:
https://linustechtips.com/topic/206482-help/#findComment-2802394
