CPU heat issue
Using HWmonitor and Intel ETU
I was using Intel ETU for stress test.
I've installed AIDA64 trial and it jumps straight to 65c. It doesnt jump between 60-70 as Intel ETU did, however.
As for the pump, a Laing DDC with a res combo.
I was using adaptive to begin with but changed to static to see if there was any difference. Could you explain why I should use adaptive please?
I should probably mention that I've been an AMD user since forever and the bios confused the crap out of me here, so i used the pre-made overclock settings that the Maximus vii Hero supplied. I recall seeing Linus or Slick mentioning something about the results being worse with those.
The DDC has excellent pressure but not the flow and both are needed for restrictive loops. 65C is alright, not really a problem for your loop. Now what are your GPU temperatures?
You should use adaptive because it only give just enough voltage for the given frequency thus aiding in lowering the temperatures and increasing the life of your CPU. Having manual voltage give the set voltage weather it is 1.2v or 1.3v all the time no matter if you are in idle or load states.
