So after buying a new case and being confused on why the manual said 'Psu Screws' rather than saying which screw inparticular I realise that power supplies come with their own screws O.o
Alright so some back story I built my rig about a year ago was a bit of noob back than, so I don't even think I realised back than that powersupplies come with their own screws I think I just used random screws from the case screws. Anyway so I am moving cases and I'm looking for my psu screws. So in my spare parts box with all the leftover stuff from my build  I found this bag
So I think that is those so I looked up the unboxing of this product on Neweggs youtube channel Now if you look at 4:00 in the video you can see when he unboxed the PSU he finds a bag of accessories as well.
Now the bag looks the same size but I don't have the molex to floppy connector which is weird I have no floppy drives. Also I seem to have some other screws but they might of been random screws I threw into there from my case screws Idk. They look like these screws I have I know it's to tell even at 1080p in the video but they have the same colour atleast. Do these look like PSU screws to you
My Gaming Setup: CPU: AMD FX-8350  |  CoolingCooler Master Hyper 212 Evo   Motherboard: Asus M5A97 EVO R2.0   Ram: Corsair 16gb 1600mhz lp (2x8)   GPU: Msi Gtx 970 |  StorageSeagate Barracuda 1tb & Samsung 840 Evo 120gb   PSU: XFX 550w Core Edition   Case: Corsair 760t   OS: Windows 7 Professional 64 bit
Peripherals: Keyboard: Corsair K70 Cherry Mx Brown   Mouse: Corsair M65 Black   Speakers: Microlab FC20 40w 2.1   Monitor: LG 29UM65 29" 2560x1080 IPS 5ms Ultra Wide
https://linustechtips.com/topic/206205-psu-screws-help/
Yes.
Well than .... that was easy... thanks
https://linustechtips.com/topic/206205-psu-screws-help/#findComment-2798809
Does it matter that much? Screws are screws, if they fit, they're fine.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/206205-psu-screws-help/#findComment-2798813
@juretrn has it about right. Those screws look like PSU screws, but most HDDs and several other components use those screws as well. There are basically two types of screw (when it comes to PC building), coarsely and finely threaded. Almost everything is threaded for one of these two screws and most PC screws will work regardless of what the head looks like. Needless to say there are custom screws for some things, but I'm sure you will know them when you see them.
You can always read manuals to make sure, there's no shame in it :D
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/206205-psu-screws-help/#findComment-2798877
