1. Budget & Location
I Have a budget of 1000$ USD. Location. CA, USA
2. Aim
 Primary Gaming and basic school needs
3. Monitors
Just one(Currently using )
4. Peripherals
Already own the peripherals needed.
5. Why are you upgrading?
Currently have these specs=
Wanting to know what i can add/Upgrade with 1000$ USD to make it more suitable for Gaming.
https://linustechtips.com/topic/205599-help-upgrading/
The only part you can use for gaming from your PC is that GTX 750 Ti. If you have a budget of $1000 then you can build a PC that can make use of a better graphics card. If you build a $1000 PC around that GTX 750 Ti then it will the limiting factor for gaming. So I suggest you make a decision whether you want to build a $1000 PC with a new graphics card (Which will give you better gaming performance) or whether you want to build a PC using that GTX 750 Ti (In which case the gaming performance will be limited by the GTX 750 Ti).
Don't get the wrong idea though. GTX 750 Ti is no slouch but when paired with components worth $1000 it will become a bottleneck.
You can reuse the DVD ROM and the SSD along with the Windows 7 OS.
https://linustechtips.com/topic/205599-help-upgrading/#findComment-2791120
oh okay I understand! Can you help me pick out parts for a new pc? Without including the thing I can salvage from it( not including the 750ti )
https://linustechtips.com/topic/205599-help-upgrading/#findComment-2791169
PCPartPicker part list: http://pcpartpicker.com/p/DJb3NG
Price breakdown by merchant: http://pcpartpicker.com/p/DJb3NG/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($234.66 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ OutletPC)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard  ($99.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory  ($78.30 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ OutletPC)
Video Card: XFX Radeon R9 290 4GB Double Dissipation Video Card  ($364.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($39.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($94.99 @ NCIX US)
Total: $996.88
Generated by PCPartPicker 2014-08-28 06:57 EDT-0400
You will be able to use your SSD and DVD ROM in this build. The processor is unlocked which means it can be easily overclocked. So I went with a good Z97 motherboard and 8 GB of G.Skill Ares RAM to match the colour scheme of the motherboard. The Hyper 212 EVO CPU Cooler will provide enough cooling for a decent overclock. The GPU is R9 290 which will easily handle all games at 1920x1080 resolution. Added a 1 TB Hard Disk for storing media and games.
Cheers! :)
https://linustechtips.com/topic/205599-help-upgrading/#findComment-2791261
Total: $996.88
Cheers! :)
thanks you very much for your help! :)
https://linustechtips.com/topic/205599-help-upgrading/#findComment-2791269
