Need help finding a case!
OKAY GUYS - I've come to the conclusion that if I want, what I want, which I do, then I have to raise the budget. I've had great help from here and the LinusTechTips channel on YT, did a lot of searching and this is my conclusion:
The 400R, the NZXT Phantom 410 and the Enthoo Pro are all more or less the SAME price in Denmark - And they are the 3 of which I have to choose.
I am very stoked about the design of the Phantom 410, looks awesome and well, I really like the looks of it and it's features. It looks clean and awesome (As a guy who loves design, Draws and paints a lot and find joy in great looking stuff, this is more or less forplay for me).
The LTT Video on YT about the Enthoo Pro looks great, though I did not like the fact that the window seems scratched at arrival (Have anyone else had the same problem, or was this just a single case flaw??(And of course I can buy without the window)). But a lot of you guys seem to prefer this case to any other at this price range, and that has made me aware and interested in it as well.
The 400R seems a bit too... I don't know, but to me it looks like what I wanted to avoid with most pc cases, getting the "Modded" look, so it's a bit of a "turn off" for me.
BUT in the end, I want value for the money, quality and that it works great. So I guess ATM it's inbetween the Phantom and the Enthoo in a final standoff.
What do you guys recommend? Why? and why not the latter? Pro's Con's? I appreciate all the help you've provided so far.
They are both good cases, so if you prefer the Phantom then it isn't a bad choice. If you look at the reviews for both cases from the same website, they both score very well.
http://www.techpowerup.com/reviews/NZXT/Phantom_410/1.html
http://www.techpowerup.com/reviews/Phanteks/Enthoo_Pro/1.html
