From start up explorer.exe does not start and in task manager it closes 3-4 seconds after i start it.
Try running other programs, it is a Program Manager for Windows,
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/205173-explorerexe-does-not-run/#findComment-2785133
I am going to go and tell you to try something. As this is the only thing that comes to mind right away.
Press win key + R, then type in "msconfig" (no quotes), then select "normal start-up" in the "general" tab.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
https://linustechtips.com/topic/205173-explorerexe-does-not-run/#findComment-2785210
