okay so im backing up my laptop and im backing it onto an old hp compaq i boot it up i prees F1 to boot i hear a beeep then it carries on booting until it says starting windows and it get sstuck on there i have left it for 4 hours now nothing... when booting up i get a notification about system time but when i click f9 to select boot order it highlights and nothing happens!! this is urgent!
thanks in advance
~James
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/205124-help-i-need-help/
Does it get stuck at the booting scree?If so check the sata mode because it may be incompatible if you switch from a 64 to a 32 bit machine
If it's on ahci switch to ide
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/205124-help-i-need-help/#findComment-2784566
it came with one sata drive. so i added a second it worked for a while then it stops!!! it gets stuck on the starting windows and the animations still working but nothings happening!
}else{
https://linustechtips.com/topic/205124-help-i-need-help/#findComment-2784582
