https://www.youtube.com/watch?v=DZareUYY_6k When installing this "backplate" for the cpu cooler (8:13) he puts that thing on the back of his motherboard. Do i have to take off all the motherboard from the case to replace the cooler? Only one side of my case can open.
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/204975-cpu-cooler/
If you don't have a cut behind the cpu socket then yes take out the motherboard but most cases have a cut around that zone so you can see behind the cpu socket.That thing is a back plate it will sustain the cooler.
ps:took a look at your case you can install it without taking the motherboard out
edit:just take off both side panels and install it.It will be easy since the back plate have a double side adhesive and it will just stick on the back of the motherboard so you can install it easier
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782732
only one side of the case opens - the front of the mobo. No man i dont have access to the back of the motherboard. Shit..
NAZIS WILL RISE.
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782795
You need to take off the other side panel if you want to install it without taking the mb out
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782810
When i open the other side of the panel there is nothing there just like a wall. There are some screws but i dont think they will open this "wall".
NAZIS WILL RISE.
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782824
In the third picture you can see a cut in the middle of the panel you should have that too.I mean it looks like your case does
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782831
you'll have to take the board out, no biggie, once you've done it 10 times you can do it pretty quick
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782848
Ok found it. I have a heatsink(radiator?) and a cpu coler blowing to it. Is this heatsink compatible with other coolers? Or the coolers will come with a heatsink? Any instructions? This is very confusing for me.
Edit: oh wait, is the cpu atached to the heatsink?
NAZIS WILL RISE.
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782884
should of got a hyper 212 for that cpu but looking at googel images id say your cooler should be super easy to mount, maybe not even needing any messing around with backplates.
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782895
"My cooler" ? Its already in there. I bought this pc a bit used but  muuuuuuch cheaper. I am not very happy about the temps - far cry 3 , metro ll - 56*C.
Any tutorial how to do all of this? :|
NAZIS WILL RISE.
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782906
The back plate is very thin.Yes the back plate is attached to the cpu cooler
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2782934
He means the new cooler. Whats the old one, stock? Those are really easy to take off. Then you need to take CPU out from socket also since you will need to clean it and apply new thermal paste. Put CPU back in and follow install instructions of new cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2791282
Those temps look pretty good, is your CPU OC'd?
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2791345
Out of the socket ? You dont need to do that to clean it.
I removed the side panels. Now its 4.2GHZ 53*C.
NAZIS WILL RISE.
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2791614
Ahh that temp for that OC is not good :S
https://linustechtips.com/topic/204975-cpu-cooler/#findComment-2791791
