First time I started up my newly built PC, the fan worked. I'm using the stock cooler for now, but I havea Corsair H80i ready to go.
Second time I start it up (after installed windows) ASUS pre-bios tell me there's a cpu fan error. sure enough the fan is still. heat steadily climbing. I have no idea what to do.
Windows is also pretty messed up, so I went onto a laptop and downloaded a bunch of drivers. (only two resolution options neither of which are 1080p, no sound, no internet)
Please help,thank you.
https://linustechtips.com/topic/204194-cpu-fan-error/
WELCOME TO LTT FORUMS!!!
So its the H80i thats the issue? Do you have a warranty for it? If so, then RMA it.
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/204194-cpu-fan-error/#findComment-2772765
Is the pump plugged into the cpu fan header?
https://linustechtips.com/topic/204194-cpu-fan-error/#findComment-2772771
did you connect the CPU fan to the correct CPU fan header?
check if the cable is not snagged on the fan blades
did you download the LAN drivers?
audio driver is the Realtek drivers
btw what mobo you are using?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/204194-cpu-fan-error/#findComment-2772774
What are your full system specs and is your fan for your H80i connected to the CPU_FAN header? As for the Windows, I would recommend to reinstall it: http://windows.microsoft.com/en-ca/windows-8/restore-refresh-reset-pc You would have to install the LAN Drivers on the CD in order to access the internet.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/204194-cpu-fan-error/#findComment-2772775
I'm not using the h80i right now. I'd like to update the drivers (got a USB with them on) but I can't get into windows. I'll check the cable right now.
i5 4690k, MSI gtx 770, asus z97 a
Have you tried accessing Windows with integrated graphics by removing your graphics card and plugging in your monitor to the motherboard?
https://linustechtips.com/topic/204194-cpu-fan-error/#findComment-2772870
I will now but the CPU problem still there, I'm not sure how long it'll last without proper cooling. Maybe I should spend the rest of the night installing the h80i
https://linustechtips.com/topic/204194-cpu-fan-error/#findComment-2772891
