Okay, i just want to know that will there be any bottleneck's or anything with this built, and if they are, well...please correct me, thanks and yes i'd like to keep it in a MITX format, because i won't be having alot of space to keep it.
http://pcpartpicker.com/p/8qvkHx
thanks in advance :D
Rorossi FTW!! :D
https://linustechtips.com/topic/203907-first-built-need-help/
Balance.exe not found
This build is not even close to being balanced. Ditch that APU immediately and get an I7-4790k/I5-4690k and a good Z97 motherboard.. Also you have gone waaaaaaaaaaaaaaay overboard on the SSD's.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768631
That Ti will be bottlenecked. For the A88X platform now...it doesn't support high end consumer GPUs. In the future, IF HSA becomes wildly adopted, then it can be a game changer. But just like everyone on here is waiting for an 880, it makes no sense now.
My first build didn't have a solid foundation. Getting your storage correct now, is great. Getting great RAM, and cooling etc...so you can upgrade more easily in the future is smart. But I would recommend going Z97 and a midrange GPU while keeping the foundation strong.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768693
Build this.
PCPartPicker part list: http://pcpartpicker.com/p/DVxMMp
Price breakdown by merchant: http://pcpartpicker.com/p/DVxMMp/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($338.99 @ NCIX US)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.98 @ OutletPC)
Motherboard: Asus MAXIMUS VII GENE Micro ATX LGA1150 Motherboard  ($208.98 @ SuperBiiz)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1866 Memory  ($169.99 @ Newegg)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  ($245.80 @ Amazon)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive  ($88.97 @ OutletPC)
Video Card: EVGA GeForce GTX 780 Ti 3GB Classified K|NGP|N Edition Video Card  ($769.99 @ Newegg)
Case: Corsair Air 240 MicroATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($129.99 @ Newegg)
Operating System: Microsoft Windows 8.1 Pro (OEM) (64-bit)  ($129.98 @ OutletPC)
Total: $2518.46
Generated by PCPartPicker 2014-08-25 13:27 EDT-0400
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768709
Plus he couldn't fit a PSU in that build to power it. It doesn't use a standard size PSU
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768716
the reason i added 2 480 gigs SSD because i need one for the build and one for my current toaster :P
Rorossi FTW!! :D
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768728
I agree with Archangel.  You have some very nice specs in there and then this APU??!!  You can also loose one of the SSD's, you don't need 2 of those things. Put that money in a i7 or i7 with a Z97 chitset motherboard and do that Noctua cooler justice  ;)
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768754
The Hadron has horrible cooling, especially for a non blower style GPU. It's hard to build in without an EVGA mobo. 500W is not enough for a Ti. A 750w is well rounded, though 1000w will run quieter. Go Node 804 or Air 240 or even a Prodigy. For mobo, go with Asus Z97 impact. The Razer Keyboard isn't fully mechanical. If you want green backlighting, go with CMStorm TK with MX Greens. I have it. It's a great keyboard.
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768775
i need this build to last like 3-4 years basically..........that's was one of the reason's to go overboard
There's no AMD platform that'll last 3-4 years.
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768804
The hadron does not use a standard PSU. Use my build.
It doesn't use standard I/O cabling either. They are just long enough to reach the EVGA mobo's headers.
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768817
my toaster did, till last year when i burnt/destroyed the PCIe slot....
and it was a athlon x2 64 4400+ with 2 gigs RAM and a galaxy geforce 9500gt 1 gb DDR3, which lasted me 5 years....so yeah
Rorossi FTW!! :D
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768831
Are you sure your not trolling?
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768836
no, I have a amd computer that's about 10 years old and works great.
I had an 8350 990FX build. It was over 2 years old and it worked, but I can't say it worked great. After 3 mobo swaps and constant Kernel power criticals, I was done with it. My friend still has a 990FX and has problems with it. So it may "work", but not for real gaming or real work.
https://linustechtips.com/topic/203907-first-built-need-help/#findComment-2768874
