Hello Everyone,
This is my first post in LinusTechTips and I need your help to decide for a Cooling Solution in my case - Cougar MX300. Many of you may say that the case looks ugly, but I got it for $24 - so I did not give importance to the looks. The case has got a size limitation when it comes to coolers and I was not aware of it when I decided the parts for my build. There are very less build videos and the forums say that the cpu cooler limitation is ~160 mm. So, here I am :)
What I like to do: I want to OC the processor to about 4.5 to 4.7. So please suggest what sort of cooling solutions I can do with this case.
Budget: I can go upto $150 approx. Anything more, I will have to do a lot of overtime :D
My Rig is
Processor: AMD FX 8350
MotherBoard: Asus M5A99FX Pro 2.0
Ram: Patriot 8 GB 1600 Class (Single Stick)
PSU: EVGA 750 Bronze B2
GPU: EVGA GTX 770 with ACX
SSD: Kingston  now v300 250 GB
HDD: WD Blue 1 TB @ 7200 RPM
Case: Cougar MX300
Cooling fans: 3x Cougar Blue LED fans. 2 at the top as exhaust(+ 1 rear exhaust)  and 1 at the side as intake - Negative Pressure Setup.
Currently I am using the stock cooler and it is very noisy and the Asus CPU monitor is showing temp as high as 61 degree celcius on gaming - WatchDogs (Got it free with the Graphic Card). Please let me know which will be a better cooler for me - Air Cooler or AIO liquid cooler. My observations about the case are,
1) Top exhaust can accomodate only 2 fans (120 mm or 140 mm) - not enough space for a 240mm radiator.
2) Case rear exhaust is only having the provision for 120 mm fan.
3) 2 exhaust on the side and 2 at the front.
4) Water cooling tube outlets are found in the rear.
5) There are no bottom exhaust fan provision.
6) Dimensions - 195(W)x450(H)x490(D)
Pics and more details at http://www.cougar-world.com/products/pc_case/mx300.html
Please help me out to decide the cooler.
Thanks in advance,
Salman.
Care and Take Care :)
https://linustechtips.com/topic/203884-cougar-mx300-cooling-solution/
