CPU air cooler
Go to solution Solved by Aniallation,
But will there be enough space? (im using a carbide spec 03) :o
so no dual fans? D:
It will be like horizontal Hyper 212.
Single fan it will fit for sure. If your GPU installs to the second slot on your motherboard then dual-fan will work too. I would still mount it vertically though.
Would it be possible to install the hyper x3 evo facing upwards? (I have a 120mm rad (h55) for the GPU with kraken g10 at the rear exhausting air out and very low profile memory sticks)
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/203605-cpu-air-cooler/
Yes, you can install it horizontally since the mounting mechanism is shaped in a square layout and can be rotated 90 degrees, just like Hyper 212, Hyper T4, etc.
"Rawr XD"
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764207
By upwards when you look at it the cooler is mounted horizontally? if you meant vertically yeah I could see you fitting your Kraken G10 in the rear end(next to the motherboard i/o) 120mm fan mount fine but the cooler would need to be quite thin (single tower only)
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764212
what do you mean facing upwards?
horizontally when you look at it from the windowed panel.
so no dual fans? D:
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764240
so no dual fans? D:
"Rawr XD"
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764258
so no dual fans? D:
That would very much depend on how much space you have left, whether the cooler has enough mounting hardware for another 120mm fan (whether it uses screws or a metal-clip mount) most air coolers are designed to have 2 fans in which config but only come with one sadly. Try finding a 15mm deep fan I believe Gelid might have one.
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764270
This would be better rather than the CPU cooler blowing into the rad right? :D+
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764281
You will likely barely notice a difference in temperature, but vertical looks nicer. The air blown out the other side of a heatsink isn't that hot.
"Rawr XD"
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764287
ah thank you :))
I have mine horizontally becuase I have an exhaust at the top and heat rises
I have the same thought process!
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764365
kudos!
HOORAH PC MASTER RACE!
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764406
I have mine horizontally, cause I have top intakes so fresh air comes in through the top, goes through the cooler, and goes out the back exhaust.
ah so you opted for positive pressure! For me personally i have my PC in positive pressure when not under load and negative when under load (the exhaust fans are tempt controlled while intakes runs 100% of the time) :D
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764616
great mids think alike except for the fact that you have noob in your username I despise that
It's to scam people into thinking i am one and i wreck them :D (in video games atleast :D)
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764617
im not the greatest video gamer but not a noob
bf4? :D
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764690
Heres my bf3 stats xD (I've played for awhile haha)
post-121155-0-90740800-1408935407_thumb.
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764872
cant afford :( and I only have three because it was on the house
take a look :D
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764875
even thoug I dont have a rank nearly as good as yours my accuracy is way better
spray and pray haha
https://linustechtips.com/topic/203605-cpu-air-cooler/#findComment-2764938
