Corsair 450D or 750D for new case [HELP]
Solved by CowsGoRoar,
@Paddle23, I would recommend the 750D. First of all, the Gigabyte Windforce 770 (3X) is a long card, so you get a lot more air to your graphics card if you had... well, more space. The 450D is a little too small, I think it wouldn't fit in E-ATX anyway.
Just like I said, you can detach the front panel and just use the bottom 3 hard drive cages (you can remove the first cage), and there's air filters almost everywhere (not on the bottom, I read. I'll look into that.) Cleaning it is a breeze.
