Hello.
I'm considering getting a 650w because of a good offer that I got.
I got a single GPU and the system I got really only needs a 500w.
Will a 650w produce more hear than a 500w, and why ?
It won't. If you look at the efficiency curve, the 650w will actually produce *less* heat than the 500W
http://www.hardwaresecrets.com/imageview.php?image=10617
This is why you should always get a PSU that's 100-200W above what the TDP of all your components needs
Also it leaves room for expansion, you won't kill your system if you miscalculate, etc.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/203257-heat/#findComment-2759003
Nope.
Your psu will only use as much power as needed. Modern units won't even bother ramping up the fan unless you are really stressing it
This.
SimRacer - Casual FSX Pilot!
Mobo: MSI B550 Tomahawk | CPU: Ryzen R5 3600 | GPU: Vega 64 Sapphire Nitro | RAM: 16GB Crucial Ballistix DDR4 3200Mhz | PSU: EVGA P2 1000W 80Plus Platinum | Storage: 256GB Samsung 840 Pro SSD - 1TB WD Black - 2TB Seagate HDD | Cooling: Dark Rock Pro 3, Noiseblocker eLoop Fans | Case: Phanteks Enthoo Luxe | Audio: Sennheiser HD598 - JBL LSR305s | Display: BenQ EX3501R, Asus VG278H
https://linustechtips.com/topic/203257-heat/#findComment-2759119
