So my mobo says DDR3 1600/1333 and my Xeon says DDR3 1600 and I have DDR3 1333Mhz RAM. Would it work. I also have some 1866 I would rather put in if it will work too.
ASUS P9D-C/4L ATX Server Motherboard LGA 1150 DDR3 1600/1333
Intel Intel Xeon E3-1220V3 Haswell 3.1GHz 8MB L3 Cache LGA 1150 80W Server Processor BX80646E31220V3
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/202746-server-parts-comp/
It should work fine.
From my experiences, the RAM frequencies stated by CPUs and motherboards tend to be pretty lenient.
https://linustechtips.com/topic/202746-server-parts-comp/#findComment-2751258
So I could prob go one speed above or one speed below without running into problems. Either of the two would be completely matched ECC sets
| F@H STATS |
https://linustechtips.com/topic/202746-server-parts-comp/#findComment-2751294
From what I know, it should all work just fine.
I do see @Ssoele here though, and he knows a fair bit more than me on this. What do you think?
https://linustechtips.com/topic/202746-server-parts-comp/#findComment-2751303
If you are working with ECC ram, I would not go about the rated speeds of the motherboard, CPU or ram itself. Use the highest that is supported by all 3, you can always underclock that 1866 memory to 1600.
https://linustechtips.com/topic/202746-server-parts-comp/#findComment-2751495
