Is a 300 Watt Power Supply enough for an intel-4670 CPU and a mid-range graphis card like an Nvidia 750/Nvidia  660. If not, what can a 300W PSU run?
It will probably have 1 7200 RPM Hard Drive.
Thanks
A 300W PSU could run an i5 4670 and a 750, yes. But you should tell us what the exact model of the PSU is or link to the specs if you can find them.
https://linustechtips.com/topic/202289-300w-power-supply/#findComment-2743565
Use PCpartpicker if you aint sure.
A 750/750ti is the only cards exept those low end cards that dont do much more than render video and play games on low settings.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/202289-300w-power-supply/#findComment-2743572
I would get a good 450w or better
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/202289-300w-power-supply/#findComment-2743593
if its a 300w that came with a per-built computer, kill it with fire upgrade to at least 450-500 watts if you are thinking of a 660. I think an antec basiq power vp-450 should be able to handle a 660 (if it only needs 1 pci-e plug), but you could do a lot better for a bit more money.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/202289-300w-power-supply/#findComment-2743972
