Hello,
I want to build my own computer and I want to use it for gaming! I dont think that I will be able to max settings out but I would prefer a system that would last me at least 3 -4 years. I don't really have a budget but I dont have thousands to spend. I live in the Netherlands.
Here is what I came up with so far:
http://pcpartpicker.com/p/tp8nyc
I still need a Case and a video card. I hope someone can adjust my build or give suggestions about the video card or case. Also if you know a better motherboard please tell me aswell!
I was thinking about a r9 270x or a nvidia card but I dont know much about this type of stuff. As I said before I cannot throw thousands at this system!\
Thanks for the help!
https://linustechtips.com/topic/201577-first-build/
-Snip-
I added a case and GPU, what do you think of it? http://pcpartpicker.com/p/vmT9wP
https://linustechtips.com/topic/201577-first-build/#findComment-2733307
That gpu is far to expensive, I have max 250. However, I really like the case but I dont like the power button and usb ports on the top, do u know a similiar case with them on the front panel? That would be amazing!
https://linustechtips.com/topic/201577-first-build/#findComment-2733355
I came up with this.
Motherboard: Gigabyte GA-Z97M-D3H Micro ATX LGA1150 Motherboard  ($86.87 @ Amazon)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card  ($249.99 @ Amazon)
Case: Xion XON-560 MicroATX Mini Tower Case  ($36.98 @ Newegg)
Total: $775.09
Generated by PCPartPicker 2014-08-21 14:41 EDT-0400
https://linustechtips.com/topic/201577-first-build/#findComment-2733500
