Random question for future build
Solved by Shaqo_Wyn,
Oh ok!
I mean, I was in between the H100i and the H220x and decided to go with the h220x just in case I get a bit more "enthusiast" and want to water cool my gpu.
Well, if I don't need to change the liquid, and I can have the noctuas on the h220x, then I think I should just go with the h220x. Correct?
Thanks again.
Yep. Enjoy ![]()
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
