Hi Everyone,
I'm building a new computer, and I want to do a triple screen setup. I have a Gtx 770 4gb, but the Nvidia site says that the maximum resolution is 4096x2160. That resolution does not reach high enough for a triple screen hd setup, but still I see many people run triple screen setups on the gtx 770, so now i'm a bit confused:P
Thanks!!
Bart
https://linustechtips.com/topic/200967-gtx-770-max-resolution/
Maximum resolution of a single monitor. You can still run triple screen 1080p through the multiple outputs of the card.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/200967-gtx-770-max-resolution/#findComment-2724811
I ran 2 1920x1200 monitors on a single 770. I have since moved to 3 1920x1200 and 3 way sli 770's and they run great. Games look awesome and it keeps up nicely with the refresh rate of the monitor. Doesn't tear or anything.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/200967-gtx-770-max-resolution/#findComment-2724818
that's per single screen. you can run 3 screens happely using a gtx 770 but I would recommend doing sli if your wanting to game
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/200967-gtx-770-max-resolution/#findComment-2724823
All I can advise is I wouldn't run more than 2 1080p monitors especially if you plan on gaming, defiantly tears and doesn't get good fps.
https://linustechtips.com/topic/200967-gtx-770-max-resolution/#findComment-2724827
Nice, i thought it was for 1 monitor but didn't know it 100%
But thanks for the fast responses!
And isn't two monitors annoying for gaming, with the gap in the middle?
not really if you get thin bezel, I love multiple monitors. Makes the games that much better in my opinion.  But one 770 you can run anything even 4k just don't expect anything higher than 20-30 fps at 4k lol
https://linustechtips.com/topic/200967-gtx-770-max-resolution/#findComment-2724917
You don't usually "game" on two screens. You game on 1 screen and keep the second separate for other information or whatever you may want. Three screens though is what people usually do for gaming; it's rare to see someone do a two-screen gaming config xD.
Also, I think eventually you get used to the bezels, but I can't be sure. I don't have a the screens nor the connection gear to run a triple monitor setup right now, so I wouldn't be able to check. I'd love to try it one day though; 3D vision surround gaming hnngggg
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/200967-gtx-770-max-resolution/#findComment-2725471
Having 2 screens is largely pointless when gaming. You can leave something open but if you click on it you'll obviously minimise your game. (Unless you use windowed mode but that's so immersion-breaking)
3 screen gaming is great for racing games in my experience but terrible for everything else.
https://linustechtips.com/topic/200967-gtx-770-max-resolution/#findComment-2741336
