  • I will be building a system in the upcoming weeks and I was thinking of a title for it. So far I have come up with Code Black, Code Red, and The Red Planet. The build will be black with a red accent, and the components are below. I am open to suggestions thank you.
 CPU: Intel Core i7-4790K 4.0GHz LGA 1150        CPU COOLER: Corsair H100i        MOTHERBOARD: ASUS ROG MAXIMUS VII HERO        GPU: ASUS ROG STRIKER-GTX760-P-4GD5        CASE: NZXT Phantom 530 (Black)        MEMORY: Corsair Vengeance Pro Series 16GB (2 x 8GB) DDR3 DRAM 1866MHz                                     HDD: WD Black 1TB 7,200 RPM SATA 6.0Gb/s 3.5" Internal        SSD: Samsung 840 Evo 2.5-inch SATA 120GB        PSU: Corsair AX760 ATX Power Supply 80 Plus Platinum        PSU CABLES: Professional Series AX850/AX750/AX650 Individually Sleeved Modular Cables — Red
-The Robot
https://linustechtips.com/topic/200915-build-title/
If I had to make a suggestion to the build, it would be the GPU. Kind of a waste to spend money on it when you could get a 770 instead. (It's not the dual GPU one, right?)
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/200915-build-title/#findComment-2724289
