GTX 760 Issue
Solved by dragoon20005,
Ok so you think it will be worth it to just go ahead and buy it? Probably his fault you mean? Lol
first off
I dont know why your friend thinks he can run a GTX760 on such an old board
second is the board only has one PCI-E x16 slot
no way he can run multi GPU setups
YoungBlade ·
Posted in CPUs, Motherboards, and Memory8 -
3
derekchan ·
Posted in New Builds and Planning8 -
1
2
6
5
7
kerriya ·
Posted in Cases and Mods13
play_circle_filled
Latest From ShortCircuit:
