Okay so I have a quick question about Radiators. Lets say I were to build a custom pc case and had two of THESE enclosed in a rectangle wooden box no wider than the actual Radiators. The rectangle encasement would be about 14 inches long and at the end there will 3 120mm AF optimized Fans to exhaust. If I were to put both Radiators (about 5 inches apart from each other) in this encasement both in push/pull configuration, would the second radiator be gimped on cooling? If so, how much?
https://linustechtips.com/topic/200561-radiator-spacing-and-cooling/
Your box would need an intake too...
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
@Visionnn
If you have both rads, one infront of the other, then it wouldn't be as effective. But in saying that too Most roof mounted rads are taking in warm air from the case.
If the front rad was taking in the warmest water and the coolest air, and the rear rad should have cooler water, but warmer air, it should even out. Maybe.
Would be best to have them side by side if possible.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
@Visionnn
Honestly, If you not over clocking your cpu and gpus in sli or anything silly like that, I dont think you'll have too many issues, just may run a fraction warmer.
