Hey everyone,
Can you help me out with a build? I have included some of the needed information, but if you need more to work off of, feel free to ask.
1. Budget & Location
My budget is somewhat flexible, but I would prefer to stay in the $1,000 - $1,200 USD.
2. Aim
I am using the system for various tasks including but not limit to programming, web browsing, and gaming (Starcraft, etc). I do like to multi-task and tend to leave many applications open running at the same time such as all of the ones listed above along with maybe Skype, TeamViewer, Outlook, etc.
3. Monitors
I will have 2 monitors and maybe a 3rd in the future. The monitors will most likely be 22"-24", but I may expand up to 30+. Recommend me a size that you think is good enough.
4. Peripherals
I need 2 monitors, keyboard, and a mouse. The keyboard and mouse don't have to be too fancy; a simple one will suffice. I will use Windows 7 as the OS.
5. Why are you upgrading?
I am upgrading because my current machine is really really old and doesn't meet my needs.
https://linustechtips.com/topic/200314-build-recommendation/
This is a tough one.. I have a build that meets what you need, and is pretty much barebones, but does not include a mouse or keyboard. :/
Okay, I managed to get it down $200 but you'll lose 8 gigs of RAM and you won't have a 280x, which I guess isn't too bad because a 280 is close enough in terms of performance.
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($149.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Micro Center)
Motherboard: Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard  ($129.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory  ($78.30 @ Newegg)
Storage: Western Digital RE3 1TB 3.5" 7200RPM Internal Hard Drive  ($47.00 @ Amazon)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($199.99 @ NCIX US)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  ($79.99 @ NCIX US)
Power Supply: be quiet! Pure Power L8 600W 80+ Bronze Certified ATX Power Supply  ($59.99 @ NCIX US)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($119.99 @ Newegg)
Total: $1015.18
Generated by PCPartPicker 2014-08-19 11:14 EDT-0400
$200 that I left out is for a keyboard and mouse, I can't tell you want to get because that's up for you to decide depending on how you use them and what you prefer.
https://linustechtips.com/topic/200314-build-recommendation/#findComment-2715157
Total: $1015.18
Great Build! Personally I'd add in a 256GB MX100 Crucial SSD to decrease load times (I guess you do open and close windows a lot). It's the best value for money right now ($112 on Amazon) and performs pretty well compared to even the 840 EVO.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/200314-build-recommendation/#findComment-2715222
Depends on whether or not @dalawh would like to add that to the budget.
https://linustechtips.com/topic/200314-build-recommendation/#findComment-2715233
probably, but I think $90 would suffice for a 'simple' keyboard and mouse :)
An SSD is hard not to recommend nowadays, especially with that budget and the low low price of SSDs, as well as the significant performance they can add to a PC.
https://linustechtips.com/topic/200314-build-recommendation/#findComment-2715319
