Hullo,
so I've got two desktops around my desk and I'm wondering if it's possible to connect them so I can at least access the second desktop's data through the primary pc?
Does that make sense? Basically I want the secondary desktop to act as an external hard drive for the primary computer but still have the secondary desktop able to function independently.
I've seen somewhere that you can reverse the pins of an ethernet cable and plug it in and the desktop should show up as a network drive. Is that right?
If someone can link me a tutorial that would be fantastic,
Thanks a lot in advance
Home is where the heart my desktop is.
https://linustechtips.com/topic/200230-connecting-two-pcs/
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714066
Yeh, you have to do a bit of cable disassembly and re-connection, I'll have a look for a tutorial about it.
Found the video I saw that had this in it:
Though you can also just buy a crossover ethernet cable which means you don't need to do any tedious cable work.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714080
Just plug an ethernet cable and share folders (or the entire drive)...
I think I saw on a wikihow article that you need a special "crossover ethernet cable" or something like that
Thanks! that looks cool but now quite what I was looking for. (currently only have one screen and switch between desktops)
ok, thanks
edit:Finally found the article that I found previously: http://www.wikihow.com/Connect-Two-Computers-Together-with-an-Ethernet-Cable
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714094
Homegroup?
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714095
Homegroup?
riiiiiiight....I've always forgotten about that... :P
But I was looking for a solution that allowed full access to a second computer's hard drive.
I thought at some point "why the hell can't I just connect the two via usb?"
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714140
ok, thanks
Aha, well I found the video I was thinking about earlier and I also found out that you can even buy crossover ethernet cables.
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714151
homegroup is quite annoying to use because of all that security reasons
ExSystems
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714154
Thanks a lot, I'll go get a crossover ethernet cable then and see how it goes
Well, Homegroup only allowed for a couple pre-designated files to be accessed.
On that note though, do you know how much of the secondary hard drive I could access with the ethernet cable?
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714205
Awesome, you should be able to access the whole drive while using a crossover cable, though I'm not certain.
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714231
Map it as a network drive, then connect it in the other PC. They're both running Windows, right?
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714237
yeah, both installed windows 7 off the same cd
Good, because I know how to do this on win7.
Go to My Computer, right-click on the hard drive, Share with -> Advanced Sharing. Click Advanced Sharing again, tick "Share this folder", press OK and OK again. On the other PC, click "Map network drive" in My Computer, select a drive letter, and folder should be \\computer\drive (on my PC it would be \\intel-pc\c). Case doesn't matter, they can be lower- or upper-case. When asked for a username and password, enter the Windows logon information on that other PC.
Assuming they're both on the same network, you won't have any problems.
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714292
Ok thanks!
I'll give this a shot once I get home (yay school)
https://linustechtips.com/topic/200230-connecting-two-pcs/#findComment-2714314
