For cases i can recommend the Corsair Air 540 that is bigger, and the AIR 240 that is mini atx and micro atx, the 240 costs 100 and the 540 about 130, but budget this is the best i can find: http://www.corsair.com/en/carbide-series-spec-01-red-led-mid-tower-gaming-case
it cost 50 US bucks and has flashy gaming LED red lights, you can order it in a variety of colors too
I love corsair cases and other parts for their serious build quality, amazing customer service if something get to your house broken and well it costs a fair bit more than other companies but you really get what you are paying for.
https://linustechtips.com/topic/199917-500-600-build-help/#findComment-2709682
PCPartPicker part list: http://pcpartpicker.com/p/4BDKsY
Price breakdown by merchant: http://pcpartpicker.com/p/4BDKsY/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($115.98 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)
Motherboard: Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard  ($109.99 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($87.31 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($55.98 @ OutletPC)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($199.99 @ Newegg)
Case: Corsair SPEC-02 ATX Mid Tower Case  ($39.99 @ Micro Center)
Power Supply: Corsair CSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($85.99 @ Amazon)
Total: $720.22
Generated by PCPartPicker 2014-08-18 17:07 EDT-0400
https://linustechtips.com/topic/199917-500-600-build-help/#findComment-2709705
Removed *
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($114.28 @ OutletPC)
Video Card: PowerColor Radeon R9 270X 2GB PCS+ Video Card  ($201.98 @ SuperBiiz)
Case: Cooler Master Elite 430 ATX Mid Tower Case  ($29.99 @ Newegg)
Total: $704.18
Generated by PCPartPicker 2014-08-18 17:56 EDT-0400
We got off to 700$ :/
https://linustechtips.com/topic/199917-500-600-build-help/#findComment-2710080
Removed *
Total: $704.18
I'm going to keep the power supply I chose in the build because I plan on upgrading components down the road. Aside from that, everything looks good man. Thank you
https://linustechtips.com/topic/199917-500-600-build-help/#findComment-2710178
