Hello everyone,
I haven't been using my PC for a week or so and today I turned it on and it came up with
Your pc needs to be repaired
File winload.exe is missing or corrupt error code 0xc000000e
I don't have the windows installation disk and I was wondering if anyone could help me :)
Thanks,
Nathan.
post-45877-0-37635000-1408342481_thumb.j
https://linustechtips.com/topic/199547-your-pc-needs-to-be-repaired-help/
Well if you have another computer then download the disk for your version of windows and it will most likely be in an iso format, what I would typically do is just extract all the files from the iso to the flash drive and have nothing else on it.
(Or use the windows USB/DVD Download tool)
Then boot from the flash drive on the computer that needs repaired.
If you have a usb drive and another pc the windows 7 isos are online for download (http://www.w7forums.com/threads/official-windows-7-sp1-iso-image-downloads.12325/) if you put the corresponding version on a usb or burn it to disk you might be able to repair that way?
