https://linustechtips.com/topic/199482-water-cooling-plan/
that radiator is JUST the bare minimum to cool that system, ideally you'd add another 240 if you're able to fit it?
Also the Swiftech blocks aren't the best (they are totally fine) but for the same money something like EK, or XSPC might be a better option as they cool all components where the Swiftech ones have a hollowed out section Sorry i've looked up the XSPC and EK ones and they are the same, I was sure they weren't well. The final report I have is aparently the swiftech ones are slightly more restrictive but it makes no difference with that D5. Ignore me, sorry for misleading.
Pic for reference.
https://linustechtips.com/topic/199482-water-cooling-plan/#findComment-2704324
I use the EVGA ACX Cooling 780ti graphics cards and my case is a Corsair Obsidian 750D. I'm not sure about what's the order of the parts, this is my first water cooling build. Maybe RES>PUMP>RAD>CPU>GPU1>GPU2>RES.
Your going to want the radiator at the end if you want cool water in your res.
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/199482-water-cooling-plan/#findComment-2704421
