So i got the ASUS R8 280X Cirect CU 2 to upgrade from my xfx hd 7770.
I install the card and everything with display connectors placed fine. I power my computer but i am not getting any display whatsoever. I am very confused and i do not know hat the problem is and what solutions are there.
Pc Specs
CPU: AMD FX-8120 X8 3100MHZ 16MB 125W AM
HDD: Toshiba 1TB 7200 rpm 3.5" SATA
RAM: Corsair High Perform Vengeance 8GB DDR3 1600Mhz 2x4
Board: MSI 970A-G46 9 Series AM3+ Motherboard
PSU: Diablotek DA Series 600w ATX Power Supply
PLEASE HELP!!! :(
https://linustechtips.com/topic/199329-problem-with-pc-gpu-upgrade/
Did you connect all the 6-8 pin connectors? Check all the connections again and make sure the GPU fit perfectly in the slot, it can sometimes be slightly crooked and not make good contact! :)
It was there perfectly. Question tho. Is it maybe because i am using a 600w psu when it says min requirements is 750w?
Well you are running some really power hungry components. Can you get a beter PSU and test it? The one you have, this is the first time I hear of that manufacturer, makes me doubt it's "600w".
Get the POS PSU out before it causes damage. Use it for target practice.
AMD Ryzen 5 3600 | Corsair H100i Pro | ASRock X570 Phantom Gaming 4 | Corsair Vengeance 32GB 2x16gb @ 3200mhz  | Vega 64 @ Stock | Fractal Design Define R4 | Corsair RM750
ThinkPad T480 | Intel Core i7 8650u | Nvidia MX150 | 32GB DDR4 @ 2400mhz | Samsung 840 Pro 1tb
well anyway get a new psu because it's not even 80 plus or bronze.
It's not even from a reputable brand! WTF is "Diablotek" sounds cheesy as hell.
Still that 600w PSU should run the GPU fine in the desktop and normal usage. 750w rec is for load. So, in game, if your PC shuts off, then it's the PSU not sending enough power. You may have got a bad card. I received a 7750 once with a bad HDMI out the box.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
If I write 600w on a 12v 500ma adapter and pack it in a PC PSU case, are u guys going to trust it's a 600w PSU? Don't be naive, that thing can't even bust out 400w, just get rid of it. It's not the GPU fault, get a decent PSU man, you went cheap on the most important part of the PC.
Im going to upgrade to this http://amzn.to/1o3gd03 and i hope that it solves my problem. The card turned on fine when i turned on my pc but i was not getting anything on screen which is what confused me the most.
Good choice, it will work I guarantee it. :)
