i own that camera and its amazing
its is THE best bang for the buck camera with interchangeable lens you will ever buy
 an APS-C camera at that price is unbeatable
 but with video you will have the choice between 60i and 30p
if thats ok with you then go for it
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/199076-sony-nex-3n/#findComment-2698781
So I can film 1080p with what framerate? Could you also tell me how long videos would I be able to film with it?
Could always buy a few spare batteries, and have those on hand.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/199076-sony-nex-3n/#findComment-2751592
