Hi, i recently build a system and i have been having some problems when playing games
What happens is that after some time (10-30 minutes) the game compleatly freezes and i have to restart the system to get out,
i have my games on a separate hard drive(Segate Barracude 1TB) , and it only occurs when im playing
Could the drive be dying?
I have updated all drivers and also the BIOS
Specs:
Windows 8.1
Intel core I7 4790k (stock)
Asus Maximus VII Hero
RAM: Corsair VEngance 16GB 1600MHz (XMP)
Asus GeForce GTX 780 Direct CU II
Kingston Hyper X 3K 240Gb SSD
Segate Barracuda 1TB HDD
thermaltake tpg-1050m series toughpower xt 1050w Power Supply
https://linustechtips.com/topic/199046-random-freeze-help/
Are you using the stock cooler? If so then that might be your problem because the cpu could overheat.
If i play a game of the ssd the freezing seems to stop so i dont think heat is the problem (yes im using stock cooler but i have just ordered an H100i)
https://linustechtips.com/topic/199046-random-freeze-help/#findComment-2698755
Overheating will usually just shut down system completely.
Many system freezes can be attributed to RAM in some way.
Although SSD's are similar in RAM in some ways also.
1. Having your game files on a separate drive could be the source of the problem. Try running it from the SSD instead. If you still have the same problem then you will know that it is something else.
2. Check the BIOS or UEFI to make sure that RAM is running at correct voltage and timings. Usually tap F2 or delete when starting up to enter BIOS/UEFI.
3. Enable Intel XMP if it is not enabled and this will set correct voltage and timings automatically.
4. If none of this works then rule out the possibility of a bad stick of RAM. Blow out the RAM slots to remove any dust and then try each stick one at a time. Consult your motherboard manual to determine which slot to use only one stick of RAM in. Usually it is slot 1 (or A) which is usually closest to CPU. If you have a bad stick of RAM then you can return the whole set for an exchange or get an individual stick replaced through Corsair RMA process.
Hope this helps!
i7-3770K @ 4.5GHz, ASRock Z77 Extreme4, G.Skill Sniper 8GB DDR3 1866 @ CL9, ASUS GTX 780, CM HAF XM, Samsung 850 Pro 256GB, WD Black 1TB x 2, EVGA SuperNOVA G2 850W, BenQ XL2420TE 24" 144Hz @ 1080p, CM Nepton 280L, Noctua Industrial IP67 2000RPM 140mm PWM Fan x 6
https://linustechtips.com/topic/199046-random-freeze-help/#findComment-2699223
