I am building a pc in the node 804 and I am getting the asus z97m-plus matx mobo and one saphire 290 vapor x and a second one later.
They are 2.5 slots so would they fit? (the mobo has this layout [pcie 3.0 x16] [pci] [pci] [pcie 2.0 x16] ) so there is enough clearence between.
would the second one fit without touching the bottom or something like that.
also would a be quiet power zone 1000w modular 80+bronze be capable of powering those
and
i5 4690k,
5 case fans,
1 hdd,
1 ssd,
2 dimms of ram
and maby later an aio water cooler.
I thank everybody that helps in advantage! HELP!
https://linustechtips.com/topic/198577-help-first-time-builder/
If you have a 2.5 slot card, the third slot on the board is unusable, so the second card would have to go in the bottom most slot.
It looks like there is enough spacing between the cards. The problem I see is the space for the bottom GPU in the bottom of the case.
https://linustechtips.com/topic/198577-help-first-time-builder/#findComment-2691685
-snips-
Oh yeah that would work because the second card would need to go in the bottom slot anyways, but it wouldn't fit in the case.
https://linustechtips.com/topic/198577-help-first-time-builder/#findComment-2691686
