You can go 2 way Crossfire in the case, but if you are going all insane it will be better to go ATX. You should tell what are you going to upgrade.
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
https://linustechtips.com/topic/198036-help-prodigy-too-small/#findComment-2685286
not that is not possible to do CrossFire
but the main problem of the Prodigy is really poor airflow
you will need to use the blower type cooler over the open ones
which is why nVidia Reference GPUs work in these tight spaces
AMD reference may be the way to go but they are loud and overheat faster
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/198036-help-prodigy-too-small/#findComment-2685310
I have a pretty good build plan. Go here-http://pcpartpicker.com/p/xt6NYJ. I was wondering if going micro atx and having a small case would limit me in the future if i wanted to upgrade. Should I go atx and define r4?
PLEASE HELP. thanks for feed back :) !
I will want to do bigger graphics cards, water cooling like h100i, and sli because i will switch to nvidia but 280x is what fits my budget. I feel like after that their would be no airflow options that are any good and generally just feel restricted.
https://linustechtips.com/topic/198036-help-prodigy-too-small/#findComment-2685388
