hello i have a pretty small but noticeable problem with my h100i. so when i boot up my system the led is a pink'ish color, so i have to go into corsair link and change it, but even that is pretty difficult to get it on the right color.
so if you have the same problem or if you have the solution plaese reply:-)
https://linustechtips.com/topic/197480-h100i-lights/
Picking colours is really easy not sure why you are struggling, there are 3 slides that you adjust up and down, or you can pick a colour
make sure if you make any changes that you save it as the main profile or it will revert upon restart
https://linustechtips.com/topic/197480-h100i-lights/#findComment-2678108
let's say that is turn up on the blue bar, then it turns green. what the meaning with that?
https://linustechtips.com/topic/197480-h100i-lights/#findComment-2678119
https://linustechtips.com/topic/197480-h100i-lights/#findComment-2678143
It's RGB. The 3 colours combine to create 16.8 million colours.
If you want just blue, turn the blue slider up and the other two down.
https://linustechtips.com/topic/197480-h100i-lights/#findComment-2678150
