BEFORE YOU START FLAPPING YOUR GUMS, YES I KNOW XP IS IN EOS STATUS AND SO ON. I'M AIMING FOR ERA-CORRECT. HER PROGRAMS DON'T SEEM TO WANT ON ANYTHING NEWER THAN CORE 2 OR ATHLON 64.
So, I have to do a basic Windows XP build for my grandma so that she can run some of her older programs. Yes, I know it is waaaaay overkill just to run PrintMaster and use a scanner/printer, but she's used to the speed of her current computer. So, here's the part list.
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler  ($16.98 @ Newegg)
Memory: Crucial 2GB (1 x 2GB) DDR2-800 Memory  (Purchased For $0.00)
Storage: Western Digital Caviar Blue 250GB 3.5" 7200RPM Internal Hard Drive  ($27.49 @ Amazon)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($46.98 @ Newegg)
Power Supply: Antec Basiq 350W ATX Power Supply  ($29.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $0.00)
Other: 3.2GHz Intel Pentium 4 (Purchased)
Other: MSI G41M-P33 LGA 775 ($59.99)
Other: Windows XP Professional SP3 (32-bit) (Purchased)
Total: $181.43
Generated by PCPartPicker 2014-08-13 12:04 EDT-0400
I have peripherals and a display already.
Should I bother adding in a cheap GT610 (this one) since I only have 2GB of RAM? My grandma doesn't really close things, so that 2GB will go fast.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/196926-basic-xp-build-am-i-missing-anything/
If you still have the money..
Go on and add another 2 gigs of RAM. And may be the 610?
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
I'd grab a 80+ Bronze PSU, like this http://pcpartpicker.com/part/corsair-power-supply-cx430m
a mATX Chassis for a mATX board wouldn't hurt either.
proud owner of alienware 13 with graphic amplifier and also a alienware X51 gaming PC!!! really powerfulL!!
xoxo samantha <3
Trying to keep this as cheap as possible. That's why I'm using a lot of the parts I already have (like 2GB of RAM, DDR2 is freaking expensive).
I had thought about getting a better PSU. And as for the chassis, I've had good experience with the 210, so I'm just gonna stick with it (and it is a good budget case).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
40$ cheaper better case and PSU
CPU Cooler: Cooler Master DP6-9EDSA-0L-GP CPU Cooler  ($7.99 @ SuperBiiz)
Case: Cooler Master Elite 430 ATX Mid Tower Case  ($27.99 @ Newegg)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($19.99 @ Newegg)
Total: $143.45
Generated by PCPartPicker 2014-08-13 12:35 EDT-0400
Total: $143.45
She didn't like the looks of the 430 (go figure) and she had one of those coolers on the CPU before... Never heard any computer component that loud before in my life. If I can get her to do the $20 MIR on the PSU, I will probably get another CX430M.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Most of the time you can get a cheque with a MIR (or a prepaid visa to buy things online) which is quite nice. The 430m is also semi-modular and 80+ Bronze (vs plain 80 plus).
Could always grab a Coolermaster N200 if you can tolerate the look for a slightly smaller footprint.
xoxo samantha <3
Thankfully size is no matter since I can put it pretty much wherever I want. I love the basement. :D
Main rig on profile
VAULT - File Server
OptiPlex 7040M
@tmcclelland455,
Since XP is not terribly demanding of storage you might consider an all ssd build - depending on just how much user storage is needed. I would run with the stock cpu cooler if it is available.
CPU Cooler: Rosewill RCX-Z90-AL 66.0 CFM Sleeve Bearing CPU Cooler  ($7.99 @ Amazon)
Storage: A-Data Premier Pro SP600 64GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Case: Rosewill R379-M MicroATX Slim Case w/300W Power Supply  ($49.99 @ Amazon)
Total: $162.96
Generated by PCPartPicker 2014-08-13 15:18 EDT-0400
