So I was just re-watching some old videos, including this one: http://youtu.be/YfcYPyxXVCo?t=1m41s
I have been using a hoover to suck up the dust from my PC, at least 2 times a month for the last year.
I open the side of the case and sucks the dust from the motherboard and components very carefully.
I don't use any kind if brush because i thought it would build up with static.
I use this cleaning method on pretty much everything and including on other peoples equipment where needed.
Linus said that you can use a hoover, providing it has a blow function and not a suck function. Apparently, if you suck dust up, it can cause static to build at the "tip". So... I am assuming the tips of the solder and/or the components?
I don't plan to change my ways of cleaning because of one comment any time soon, though I never really thought about this "problem" before.
Can someone explain this constructively with some evidence or something?
Edit:
If I lightly brush my hand over the components after the cleaning process, is this a safe way to defuse any static that might have built up?
If someone finds some sort of sciency guide as to why it is dangerous, let me see. I like all that jazz :3
https://linustechtips.com/topic/196829-cleaning-method-is-dangerous/
When you suck up the dust, it can build up static by friction which can discharge into your components, which are all grounded and therefore a likeley target. I personally have vacuumed my PC before and never had any problems but i switched to compressed air and i am sure you will too once you will actually damage something. But for the most part it works too.
who cares...
I used this to clean my older PCs... But now, I'm using a mix of this and some compressed air action...
Still, I work barefoot and I am touching the nozzle so there are no untoward incidents...
