so at first we thought it was a bad HDD becasue I could get past the bios and windows would try and start. so we replaced the HDD but then it wouldnt start up. I would press the power button and the LED light on the bottom left would blink once and it wouldnt start like as if it were shorting out somewhere. any help?
https://linustechtips.com/topic/196536-dell-n5010-laptop-problem/
the screen is pluged in
i don't get screen plugged in, unless you have hooked the laptop to a external monitor, if you hooked it up and it doesn't show anything then it's the graphics on the laptop might be the problem. I had this problem on my old hp laptop so i replaced it.
I ment that I tool the laptop apart and pluged back in the screen.
