PC Gaming build guide
Solved by brob,
You may find that an i5-4690K and z97 motherboard are actually less expensive than a 4670K and z87 motherboard.
Instead of a WD Black I would suggest a WD Blue or Seagate Barracuda.
An ssd really is needed. Samsung 840 EVO or Crucial MX100 are popular choices. But you can consider virtually any ssd from a known manufacturer. SSD are so fast that the speed differential is unnoticeable in most uses.
The R9 290 is arguably better than the GTX 780. I suggest you pick the least expensive.
You may want to consider an IPS panel monitor instead of TN. They have better color reproduction and wider viewing angles.
I would suggest Windows 8.1. It will be supported for the longest time and new drivers/hardware will work with it.
