I've posted this in troubleshooting, but I didn't get much help there.
I'm using the following system (relevant specs):
  • Intel Core i5 4670K
  • Gigabyte GA-Z87X-D3H
  • Gigabyte GeForce GTX 770
  • Corsair Vengeance LP CML8GX3M2A1600C9
  • Seasonic G-Serie 650Watt
The system is running flawless, but when I check event viewer I notice that there is the following error:
  • Kernel-Power Event 41 Task (63)
I shut down my PC (properly, via Windows), start it up the next day. 1 in 5 times (or something close to that) it shows the Kernel-Power Event 41 Task (63) error.
I have no problems with the system, it's running great and I haven't had a single BSOD/unexpected shut down since I build it. However, the error in the event viewer shouldn't be there, right?
https://linustechtips.com/topic/196458-kernel-power-event-41-task-63/
