Hey Ya'll
I want to upgrade to a new socket
and i would like your opinion on my build
i have seasonic 500 80+ bronze
HIS hd 6950 with accelero xtreme 7970
asus xonar dg
nzxt source 210 elite case
sold my mobo and cpu and ram (p5ql-epu + q9550 + 8gb kingston ram)
getting
asus p8z68-v lx (90$)
i5 3570 non k version (for 160$)
and kingston hyper x 1600 8gb (2x4gb) -- for 70$)
ocz agility 3 120gb (for 80$)
what do you think so far
i heard you could enable trim through a modded bios
and pci-e 3 is not important and i have dedicated controller for usb3
biggest question is the ivy cpu works good with z68
(planning on getting sandy bridge k version later on 2500k 2600k or 2700k)
|| CPU Intel i7 3770K || MOBO ASRock H77M || RAM 8GB 1600mhz || HDD 1TB 7200 Sata II || SSD OCZ Agility 3 120GB || GPU EVGA GTX 670 2GB FTW (boost core 1240mhz) || CPUCooler CM 212 EVO || PSU Seasonic M12II EVO 750W || CASE NZXT Phantom V2 (Pink-lol) || H-Phones Sennheiser HD600 || Gamepad XBox 360 Wireless Controller || Mouse Logitech G102 || K-Board CM Storm Trigger (MX Black) || Monitor Dell P2414H || AV Common Sense ||
https://linustechtips.com/topic/19639-upgrade-advice/
wait for haswell if you can.
why upgrade to 2500k? the 3570 is newer.
so you're saying that a non oc'd 3570 would be better than an oc'd 2500k or 2600k?
https://linustechtips.com/topic/19639-upgrade-advice/#findComment-232172
