so i made this equation
x3+11x2+28x = 1872
x = 9
the problem is i can't show the whole process of getting 9 well, because once i factor the cubic equation it's pretty easy to use trial and error but i need to see how i can get 9 without trial and error. i am asking because i need to show solutions for my project. now if you think i need to find the solutions for myself and i should not ask people to do my project then please tell it and report the thread to get it closed.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/196300-math-problem/
x3+11x2+28x = 1872
x = 9
http://www.wolframalpha.com/input/?i=x3%2B11x2%2B28x+%3D+1872
https://linustechtips.com/topic/196300-math-problem/#findComment-2662502
x(x^2 + 11x + 28) = 1872
x(x-7)(x-4) = 1872
X can't be 0, 7 and 4.
Then go on.
Factorize 1872.
https://linustechtips.com/topic/196300-math-problem/#findComment-2662511
well, it requires pro to get a step by step process.....
https://linustechtips.com/topic/196300-math-problem/#findComment-2662521
x(x+7)(x+4) = 1872
X can't be 0, - 7 and - 4.
Then go on.
Factorize 1872.
Fixed :D
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/196300-math-problem/#findComment-2662539
Fixed :D
Oh.
I thought it was -11x.
My bad
https://linustechtips.com/topic/196300-math-problem/#findComment-2662551
x(x-7)(x-4) = 1872
Then go on.
Factorize 1872.
can you do it until you get 9? just tell me if i'm asking too much.
https://linustechtips.com/topic/196300-math-problem/#findComment-2662666
x3+11x2+28x = 1872
x = 9
x3+11x2+28x = 1872
x3+11x2+28x-1872 = 0
(x-9)(-x2-20x-208) = 0
^this is how you get to x-9^
I needed to remember a bit of my introductory college algebra there...
Edit: Synthetic division will make your life easier since you already know one of the factors...
https://linustechtips.com/topic/196300-math-problem/#findComment-2662717
x3+11x2+28x = 1872
I am in 4th year high school (last batch of old curriculum here. students after us will follow k12 if that means anything there).... dunno if this is easy for kids my age.
how did you use synthetic division? i know a bit of it. but what factor did you use?
https://linustechtips.com/topic/196300-math-problem/#findComment-2662818
You gave x=9 as a solution to the equation... I worked back from there...
x3+11x2+28x = 1872                <----- Your original equation
x3+11x2+28x-1872 = 0             <----- Move everything to the left so it equates to zero... (easier to confirm if x=9 at this stage)
                                                 <----- Synthetic division using 'x-9' as divisor (not too sure about the term, it's been 2 years since I last handled math)
(x-9)(-x2-20x-208) = 0               <----- The other factor (aside from 'x-9') is the quotient from synthetic division...
I'd post my solution scratch paper if my handwriting was half-legible...
But here's a quick and dirty tutorial instead...
www.purplemath.com/modules/synthdiv.htm
Also, are you graduating by the end of this year or do you have two more years (thanks to K12)? (I see you're also from the Philippines...)
https://linustechtips.com/topic/196300-math-problem/#findComment-2662858
well, the thing is, we assume that we don't know that x = 9. we have to arrive to that.
i will be graduating by the end of this academic school year.
https://linustechtips.com/topic/196300-math-problem/#findComment-2662878
3 words to live by with this:
Trial and Error
protip: use your instinct when dealing with problems like this... (i.e. factor out 1872 to the prime factors, then choose the less-occuring factors first (this is a hit or miss))
protip: when in doubt, move to the next item and return to the harder ones once you've answered everything else
protip: when all else fails BRUTE FORCE...
If you're taking the UPCAT this weekend, hopefully I'll get to see you on campus at Diliman (if you're aiming for that one) when your classes start...
https://linustechtips.com/topic/196300-math-problem/#findComment-2662894
Trial and Error
well, i could use trial and error and i always use that but this time i need to show how i got it because we need to make word problems and show the solution on a written report. but, i could just put use trial and error since it's so late and i need to make 1 more quadratic (already did 1) and 2 more linear (which is pretty easy but i need to think of situations). i will be taking the UPCAT in AA so i won't seee you there at diliman. maybe next year when i study there (hopefully)
https://linustechtips.com/topic/196300-math-problem/#findComment-2662923
well, i could use trial and error and i always use that but this time i need to show how i got it because we need to make word problems and show the solution on a written report. but, i could just put use trial and error since it's so late and i need to make 1 more quadratic (already did 1) and 2 more linear (which is pretty easy but i need to think of situations). i will be taking the UPCAT in AA so i won't seee you. there at diliman. maybe next year when i study there (hopefully)
Just write that you've tried the divisors of 1872. Trial and error is your only way of solving this equation.
Then you can divide/factorize and get an equation of order 2 which you can solve easily with the apropriate formula.
There exists a formula for solving polynomial equation up to the order of 4, but the last two ones are too advanced in your case.
https://linustechtips.com/topic/196300-math-problem/#findComment-2662955
For quadratic equations (2nd power of x), you can have parabolic trajectory or speed/acceleration problems... Look for examples in your physics books and try to make up some equations that follow the mathematical 'format'...
For the linear ones, you can make up some constant velocity motion problems...
These things are what appear in some College Algebra (Math 11, Math 14, and Math 17 in UPD) classes...
Hopefully you're not yet required to do 3-variable algebraic equations yet (but you'll need them in college math)..
Edit: Also trial and error is the only way to do this as @TideRower said... By 'quadratic', it means that the maximum exponent of 'x' should only be 2...
Protips for UPCAT would be:
Wear comfortable clothing, bring food and drinks, and relieve yourself before the exam starts...
Browse the questions for up to a full minute before you start answering the exam (esp. math and science)
Speed through the questions you know, and leave those that you don't blank...
Guess only when you have at most 75% conviction that that is the answer (the test is right-.25wrong)...
https://linustechtips.com/topic/196300-math-problem/#findComment-2662992
thanks for the tips.
mock exams were hard. is the upcat easier? people tell that mocks are harder.
https://linustechtips.com/topic/196300-math-problem/#findComment-2663116
Depends on how well the mocks were made... If you pass the mocks, you'd usually have a higher chance of passing and if you do pass the UPCAT, you can most likely pass everywhere else...
Oh and one final tip, get enough sleep for the exam... I've seen someone sleep through parts of the alotted exam time...
https://linustechtips.com/topic/196300-math-problem/#findComment-2663131
