You probably want to exhaust towards the back or top of the case.
I would recommend a push configuration, so towards the I/O.
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
Towards the io is best, especially if you have front fans and one in the rear, which is more or less in line with where the cooler would sit. If you have intake fans on the side and exhaust on the top, you would get effective cooling with is mounted vertically, however I wouldn't suggest that fan config without a front intake as you could create a 'dead area' around the drive bay. IMHO, the safest option it the common front to back airflow.
OnePlus 6T
