I had a spare RGB LED light set with the remote, converter etc. and then I bought a DC to molex adapter. It work fine but I could figure out how to mount the damn LEDs. Im working in a define r4. I tried hot glue, and after about 5 times burning myself they wouldnt stick and I gave up. Suggestions?
https://linustechtips.com/topic/196159-pc-case-rgb-lighting-solution/
Use 3M exterior double side tape super sticky and resists peeling form heat or if you'd like it to be removable use 3M dual lock(steroids version of Velcro).
http://www.scotchbrand.com/wps/portal/3M/en_US/ScotchBrand/Scotch/Products/Catalog/~/Scotch-Outdoor-Mounting-Tape?N=4335+3294603510+5584757&rt=rud
