Yes 80'c is safe. the i5-4670K is rated upto 100'c. BUT at around 82 to 85'c the cpu will throttle down and start running at slower speeds or turn off 1 to 3 off it's cores. if it thinks it's getting to hot. I personally try and keep mien under 70 if i can just so i know it will never throttle on me.
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/195854-i5-4670k-safe-temps/#findComment-2656398
Yes 80'c is safe. the i5-4670K is rated upto 100'c. BUT at around 82 to 85'c the cpu will throttle down and start running at slower speeds or turn off 1 to 3 off it's cores to if it thinks it's getting to hot. I personally try and keep mien under 70 if i can just so i know it will never throttle on me.
The CPU will not throttle down below 100°C. That's something else throttling it, maybe parts of the motherboard like VRM's or something.
https://linustechtips.com/topic/195854-i5-4670k-safe-temps/#findComment-2656437
