List made by @CoolBeans
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($139.99 @ SuperBiiz)
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard  ($74.99 @ Amazon)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Amazon)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  ($289.99 @ Amazon)
Case: Cooler Master Elite 430 ATX Mid Tower Case  ($39.99 @ Newegg)
Total: $758.18
Generated by PCPartPicker 2014-08-10 23:24 EDT-0400
https://linustechtips.com/topic/195478-part-help/#findComment-2651479
http://pcpartpicker.com/p/Pn34ZL
I'd get a Fx-6300 instead to save some money, it doesn't really reduce performance and there's still 6 cores.
750ti is really good Bang for your buck
I suggest an SSD, and an upgrade with a HDD in the future,
There's a single DIMM for easy upgrade to 16gb in the future if you have the cash
Don't forget the cost of an OS!
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/195478-part-help/#findComment-2651509
I'd try to find a R7 265 at that price.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/195478-part-help/#findComment-2651525
